Redistributing select static routes into OSPF
Jul 31st, 2007
My Catalyst 3750 switch has a long list of static IP routes, and I also run OSPF.
How can i easily select a few of those static routes to be redistributed into my OSPF process ?
Can this be done without using route-maps ?
graemeporter Tue, 07/31/2007 - 03:28
  • Bronze, 100 points or more
I'm not really any kind of OSPF expert, but maybe you could add the subnets to an access list, and distribute the access list via OSPF (albeit, not without using route-maps)
We use something like this :-
______________________________________________
router ospf 1
redistribute static metric 100 metric-type 1 subnets route-map STATIC-ROUTES-TO-OSPF
default-information originate metric-type 1
ip access-list standard STATIC-ROUTES
permit xxx.xxx.xxx.0
permit xxx.xxx.yyy.0
permit xxx.xxx.zzz.0
route-map STATIC-ROUTES-TO-OSPF permit 10
match ip address STATIC-ROUTES
Where the ACL "STATIC-ROUTES" simply permits the subnet address for each static route you want to have redistributed.
Hope this helps!
Kind regards
Graeme
