Translation Pattern Database
Jul 31st, 2007
Does anyone know where the Translation Patterns store the data.
LouisKoekemoer_2 Tue, 07/31/2007 - 04:24
That's correct.My customer is using a .asp file to search their speed dials. Any user should be able to dial any speed dial(Translation pattern) All translation patterns are in a partition. What I need to do is to change the result that it gives you ie ?London? the number will be ?0044??. I need it to display the actual translation number ie ?5000? as everyone should be able to use it, but when you try and dial it, it actually dials the ?0044?? number and not the ?5000? number.
I copied the files to replicate this cenario in my lab and I managed to get it so far to enter my search criteria, but it does not pick anything up.
Kind Regards
