ping problem
Answered Question
Jul 31st, 2007
hello
there are two 3550 connected using the fa 0/1 port and althought i can ping one another throught interface vlan1 , i cant ping to the interface fa0/1 from the vlan1 using extended ping. also i cant see any routing update in the routing table.
can anybody help ?
thanks
Correct Answer by hardiklodhia about 9 years 9 months ago
can u ping 100.100.100.1 from that host? whts default gateway configured on ur host?it should be 192.168.12.5
Overall Rating: 5 (1 ratings)
Edison Ortiz Tue, 07/31/2007 - 06:07
  • Hall of Fame,
    Founding Member
Can you modify your RIP environment with Version 2 and disable auto-summary ?
For instance:
router rip
version 2
network 100.0.0.0
network 192.168.12.0
network 192.168.30.0
network 195.167.73.0
no auto-summary
on both routers
bkoum Tue, 07/31/2007 - 22:04
hello
i tested it but still nothing
Mpoumpoulinas42#ping
Protocol [ip]:
Target IP address: 192.168.12.25
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 100.100.100.1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 192.168.12.25, timeout is 2 seconds:
Success rate is 0 percent (0/
i was thinking it would be easy to connect two 3550 with routing but i can understand why its so complecate.
hardiklodhia Tue, 07/31/2007 - 22:51
  • Bronze, 100 points or more
hello,
as per ur config,ip address 192.168.12.25 belongs to wht? host connected fa0/3 of Mpoumpoulinas42? or anything else??
if host then whts configured dg?
first try normal ping whether it is pinging.
let us know the results.
rgrds,
bkoum Tue, 07/31/2007 - 23:08
yes , host 192.168.12.25 belongs into a switch connected at fa0/3 ....normal ping respond 5/5.
Correct Answer
hardiklodhia Tue, 07/31/2007 - 23:27
bkoum Tue, 07/31/2007 - 23:41
It should be but it is nt :) this maching connected to the internet via another adsl router ...thanks
