c2821 HARDWARE
Jul 31st, 2007
Does anyone know why i cannot see serial interfaces on a WIC 2T module inserted on a C2821 router.
graemeporter Tue, 07/31/2007 - 04:21
Hi there,
If you do "show version", does the router list "2 Serial(sync/async) interfaces"?
Have you tried the WIC in another slot (or, if possible, another router)? If there is a hardware issue, it would be good to try this to rule out either the router or the WIC as being faulty.
Kind regards,
Graeme
donchisel Tue, 07/31/2007 - 04:59
No it doesn't display the serial interfaces.
The module has been tested okay on another box (2621), but no slot in this particular box (2821) can see it. Other modules (like vwic 2mft-E1) is currently producing in the box. See output below.
Cisco 2821 (revision 53.50) with 247808K/14336K bytes of memory.
Processor board ID FTX1031A3RK
2 Gigabit Ethernet interfaces
36 Serial interfaces
8 Channelized E1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Danilo Dy Tue, 07/31/2007 - 04:29
WIC-2T is supported in Cisco 2821 Router with a minimum of 12.3(8)T4 IOS
What is your IOS version?
donchisel Tue, 07/31/2007 - 04:49
See below the output showing my version;Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(3e), RE
LEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 13-Jun-06 23:24 by alnguyen
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
Danilo Dy Tue, 07/31/2007 - 05:06
All C2821 4 on-board slot is for HWIC, so it shouldn't be a problem which slot you put the WIC-2T card. Its different for other model though.
Can you post the complete output of "show diagnostics"?
vmilanov Tue, 07/31/2007 - 09:47
Also, you can observe the output from these commands:
- show inventory
- show diag
HTH.
