How to configure a special Incondicinal Forward
Answered Question
Jul 31st, 2007
I want to configure an incondicional forward from a phone to other that it can't be possible to disable by user with the corresponding softkey.
Is it possible?. How?.
I use CCM 4.1.
Thanks.
Correct Answer by Rob Huffman about 9 years 10 months ago
Hi Carlos,
I thought that this was an interesting question :) Here is how I just set this up.
1. Configure a New Softkey Template (I called mine NoCfwdAccess)
2. On this new Template move the Forward All (CFWD) over to Unselected Softkeys/Update
3.Apply this new Softkey Template to the Phone in question. Now it has no CFWDALL Softkey
4. From the Directory Number Configuration Page for this Phone, Apply the Extension you want this phone to Call Forward All to and Update/Reset
5. This phone now shows Forwarded to xxxx with no ability to change this.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Tue, 07/31/2007 - 06:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Carlos,
Hope this helps!
Rob
