cannot login to WCS with root/public
FRANK SCHADE
after a new installation of WCS 4.1.83 I cannot login to WCS using the default account root/public.
Is there another account or a way to reset it???
ericgarnel
Level 7
Level 7
This is from the release notes:
the WCS Password
You can change the WCS application root user or FTP user password. This option provides a safeguard
if you lose the root password. An executable was added to the installer /bin directory (passwd.exe for
Windows and passwd.sh for Linux). Follow these steps to recover the passwords and regain access to
WCS.
Note If you are a Linux user, you must be the root user to run the command.
Step 1 Stop WCS.
Step 2 On a Windows operating system, change to the WCS bin folder. (Linux does not have a WCS bin folder.)
Step 3 Perform one of the following:
Enter passwd root-user to change the password on the root account for WCS (not the
root account for access to the operating system on which WCS is running). The newpassword is the root
login password you choose.
or
Enter passwd location-ftp-user to change the FTP user and password.
The newuser and newpassword are the FTP user and password you choose.
Step 4 The following options are available with these commands:
? -q ? to quiet the output
? -pause ? to pause before exiting
? -gui ? to switch to the graphical user interface
? -force ? to skip prompting for configuration
ericgarnel
Level 7
Level 7
the WCS Password
WCS.
Step 1 Stop WCS.
or
