Upgrade path for IPCC 4.0 to 5.0?
Jul 31st, 2007
Can anyone tell me if there is an upgrade path from IPCC Express 4.0 to 5.0?
I understood it to be
4.0 - 4.5(1)SR1. Then 4.5SR1 to 5.0?
Thanks in advance!
Tim Moffett
Overall Rating: 5 (2 ratings)
lpezj Tue, 07/31/2007 - 05:14
I think that you don't need to upgrade to version 4.5. You can upgrade to version 5 from version 4.
Keep in mind that ypu need to upgrade first your CallManager to version 6, prior to aupgrade IPCC Express to version 5.
IPCC Express 4.5 works only with CallManager 5.
Hope this helps,
Juan Luis
Chris Deren Tue, 07/31/2007 - 08:29
IPCCX 5.1 works with CM 5.X as well.
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/crscomtx.pdf
You can not upgrade directly from 4.0 to 5.0, the only supported upgrade is from 4.5.
There is no upgrade path from 4.0 to 5.0 as you have to rebuild the server.
So, to upgrade IPCCX 4.0 to 5.0 you have to rebuild the server as well. Keep in mind that IPCCX 5.0 requires windows 2003 server as well.
HTH, please rate all helpful posts!
Chris
tmoffett Tue, 07/31/2007 - 13:45
So, the million dollar question is: Is there a data migration option, or is this a complete rebuild and application development effort?
Thanks!
Tim
tmoffett Fri, 08/03/2007 - 09:41
Thanks everyone for the replies...
Can anyone comment on the compatibility of the actual scripts?
Thanks in advance!
Tim
Chris Deren Fri, 08/03/2007 - 11:39
The scripts should work just fine, as the script editor has not been changed at all.
Chris
akaradetch.n Thu, 06/26/2008 - 23:46
What is the best solution to migrate data to new 5.0?
Can I use BARS to backup (from 4.0) and restore (on 5.0)?
Waiting for your help, thank you in advance.
Chris Deren Fri, 06/27/2008 - 06:43
There is no migration from 4.0 to 5.0, you will need to do the following:
manually backup all of your scripts, docuemnts, grammar, prompts, etc
take screenshots of all subsystems configurations
take screenshots of all CAD configurations
Rebuild the server with Cisco provided windows 2003 server
install UCCX 5.0
import all files, rebuild all configuration
Sorry, this is the only way :-(
Chris
goranpilat Thu, 07/03/2008 - 13:20
Hi Chris!
I am also preforming 4.0(5) express premium->5.0 upgrade. It will be running with CCM 6.1. What I find confusing is ordering this upgrade. Those CCX-UPG part numbers cost 0$ on configurator tool, is that right? Is CCX-UPG-P-40-50= ok in your opinion? Why don't I have win2003 included in this part number like it is included in CCX-UPG-P-40-60=??? Is there need to order anything else if the hardware is ok?
Please, I need any piece of advice.
Best regards,
Goran
Chris Deren Fri, 07/04/2008 - 05:01
If you are covered with SmartNet software subscription the upgrade is always free. If you dont have a valid subscription then I belive you have to buy the complete product. Instead of going thru configuratoin tool I would recommand going through PUT assuming you have valid smartNet on the product, Cisco will send you the UCCX media along with windows 2003 media this way for sure.
HTH,
Chris
Jeff Garner Mon, 07/07/2008 - 05:54
Has any one done the upgrade from via the PUT tool? I was able to complete the install however the license file generated from the PAK / Serial would not take...
The software would also not take my 4.x license...
antonio.vazquez Thu, 07/03/2008 - 23:17
Why don't you migrate to new 6.x (CCM 4.3)?
There is a direct path to do this migrate indeed of doing a migration to 5.x.
akaradetch.n Mon, 07/07/2008 - 01:55
Actually we are upgrading from CCM4.2 to CUCM6.1 (latest), that means we have to upgrade to IPCC 5.0 because CUCM6.1 doesn't support for IPCC 6.0 (from compatibility matrix).
Any recommend for this case?
