cwcli invreport - show operational status of ports
kviola1
Using LMS 2.6, is there any way to produce a limited "Detailed Device Report" to show selected information to include System Information MIBs, Chassis Information, Processor Port and Module Port Operational Status? I need to find out the number of active ports verse the total number of ports available on all of our managed switches. If I produce a "Detailed Device Report", the number of "OK"s vs "StoppedOrSuspended" under "Operational Status" for "Processor Index" and "Module Index" will enable a count but the excessive amount of data makes it difficult to work with as a .csv file import to Excel.
Any ideas on producing a subset of the "Detailed Device Report" report or any other commands that can provide this information?
Thanks for any help.
Ken.
yjdabear
Have you explored the options under Campus Manager -> User Tracking -> Reports -> Report Generator -> Switch Port Usage ?
Yes - it will provide total ports but not number of active ports. The custom reports under Campus are limited unless there is good query that can be used in ut to obtain that info.
