Using HSRP with SRST
Jul 31st, 2007
Is there anyway to use the HSRP address for the SRST reference. This would allow for you to have multiple SRST routers for redundancy while avoiding the limitation of only haveing one SRST reference per device pool.
gogasca Tue, 07/31/2007 - 22:16
  • Green, 3000 points or more
Thats definitly supported.
If you are using S-SRST thats not supported,
brandondelano Wed, 08/01/2007 - 04:20
Could you point me to a white paper or give further explanation on how to properly set this up?
