Authentication with Single Default Password
Answered Question
Jul 31st, 2007
Is there a way to extract username out of a database of users, but actually have their passwords all the same... Trying to get around not having to create a large amount of accounts...
AJ
Correct Answer by rochopra about 9 years 6 months ago
If you have a user database and you are trying to upload it into ACS, you can have a look at the following link to import users in ACS:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/acs41/user/a_csutil.htm#wp365101
Hope this helps
~Rohit
Overall Rating: 5 (1 ratings)
