creating a Route Point with the same number of the extension
Jul 31st, 2007
when creating a CTI routing point with a number which already exists as extension, the CCM accept this. Is there a specific reason why it is possible to use the number twice ?
Ingrid
Chris Deren Tue, 07/31/2007 - 08:19
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
That creates a shared line appearance, there are compeling reason for having those. However if you are using IPCC you should not create shared line appearances.
Chris
