diff vlans from cisco4506
Answered Question
Jul 31st, 2007
Hi Experts,
I am trying to figure out something on the Cisco4506 inter-vlan routing.. As understand, If we configured, Interface vlan 3 for 10.30.3.0 / 24 and interface vlan 4 for 10.30.4.0 / 24, PC of 10.30.3.4 will be able to ping to 10.30.4.4 PC connected to 10.30.4.0 network. Is this statement valid? Assumption here is there is no access-lists applied on the interface vlan.
thanks in advanced,
Correct Answer by Edison Ortiz about 9 years 7 months ago
One more thing, do you have multiple routers sharing the Vlan hence the need for HSRP ?
Can we also see the same from the other device
show ip route
and
show stand
Correct Answer by ankbhasi about 9 years 7 months ago
Hey Cindy,
Yes you have to enable "ip routing" to make communication work between vlan. "Ip routing" is by default enabled on IOS releases.
But incase if you have disabled it you can enable going to configu mode.
Switch(config)#ip routing
Try that and see if it helps!!
Ankur
Overall Rating: 4.3 (3 ratings)
Edison Ortiz Tue, 07/31/2007 - 07:24
  • Hall of Fame,
    Founding Member
As long as both segments point to the switch as the default gateway, Yes.
ankbhasi Tue, 07/31/2007 - 07:35
  • Cisco Employee,
Hi Friend,
In addition to Edison post assuming "ip routing" is enabled then YES you are right.
Ankur
cindylee27 Tue, 07/31/2007 - 08:18
Hi Guys,
Thanks for your advise.. For eg, i have the config as below.. I would like to have the Users from Vlan13 to talk to Vlan14..with the IP Routing, what is the default gateway that I should set so that both of them can talk to each other???
Thanks in advanced again..
interface Vlan13
ip address 10.1.13.200 255.255.255.0
ip helper-address 10.1.18.120
no ip redirects
no ip proxy-arp
ntp disable
standby 13 ip 10.1.13.254
standby 13 priority 110
standby 13 preempt
interface Vlan14
ip address 10.1.14.200 255.255.255.0
no ip redirects
no ip proxy-arp
ntp disable
standby 14 ip 10.1.14.254
standby 14 priority 110
standby 14 preempt
glen.grant Tue, 07/31/2007 - 08:22
  • Purple, 4500 points or more
All client pc's in vlan 13 have to be pointed to 10.1.13.254 and all client pc's int vlan 14 have to be pointed to 10.1.14.254 .
ankbhasi Tue, 07/31/2007 - 08:23
  • Cisco Employee,
Hi Cindy,
In your case you have configured HSRP on your vlan interfaces so for machines in vlan 13 you should configure gateway address as 10.1.13.254 and for machines in vlan 14 gateway address will be 10.1.14.254.
Had it been the case where you have not configured HSRP then vlan 13 machines should have gateway configured as 10.1.13.200 and machines in vlan 14 should have gateway address as 10.1.14.200.
Ankur
*Pls rate all helpfull post
cindylee27 Tue, 07/31/2007 - 08:28
Yup, Ankur.. I will rate those helpful post..
but one funny thing is..
I can';t ping the PC from vlan13 to vlan14..is the command applied at the interface prevent it from tracert or ping?? btw, this config is not IP Routing enabled. Will this cause it as well?
thanks..
Edison Ortiz Tue, 07/31/2007 - 08:31
  • Hall of Fame,
    Founding Member
Please post the output from typing
show ip route
and
show stand
cindylee27 Tue, 07/31/2007 - 08:41
Hi Edison,
I am currently at home now..:) will post to you all when back to office tomorrow..
Thanks guys..and will keep you all updated.
Ankur, my config didn;t have Ip routing statement,is that mean tat it is disable or not shown? How can i go about checking if ip routing is enable? by showing "show ip route"?
Correct Answer
Edison Ortiz Tue, 07/31/2007 - 10:01
  • Hall of Fame,
    Founding Member
show ip route
and
show stand
Correct Answer
ankbhasi Tue, 07/31/2007 - 08:37
  • Cisco Employee,
Hey Cindy,
Ankur
cindylee27 Tue, 07/31/2007 - 19:03
Thanks Guys!
Managed to sort it out..they are indeed able to ping each other..There is a firewall utility which block the pinging..disable it, it works..
But, Ankur.. just one question..you were saying by default,it is IP Routing enable..how can I check that if it is not showing on the config sh run file??
I have rated you guys post ya..:)
thanks again..
mahmoodmkl Tue, 07/31/2007 - 20:43
  • Gold, 750 points or more
what Ankur meant was the ip routing is enabled by default in the current IOS releases.It will not show up in u r running config.I think u can type no ip routing and check,if it shows up in the running-config then it means that it was enabled.
Mahmood
Edison Ortiz Wed, 08/01/2007 - 05:42
  • Hall of Fame,
    Founding Member
You can verify if routing is enabled by typing
show ip route
With IP routing enabled, you get something like this:
Rack1SW2#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Without ip routing enable, you get something like this:
Default gateway is not set
Host Gateway Last Use Total Uses Interface
ICMP redirect cache is empty
