vrf lite
Jul 31st, 2007
I want to use vrf lite with ipip tunnel but unfortunately it works one way but not the other.
here is my config:
ip vrf uk
rd 69:129
interface Tunnel2
description IPIP tunnel to UK
ip vrf forwarding uk
ip unnumbered Vlan2
tunnel source Dialer0
tunnel destination <public_tunnel_router_ip>
tunnel mode ipip
tunnel path-mtu-discovery
tunnel vrf uk
ip route Dialer0
ip route vrf uk Tunnel2
interface Vlan2
ip dhcp relay information trusted
ip address
ip helper-address global
i can ping throught the tunnel from but i can t ping from the router to throught the tunnel (ping source vlan2)
the odd thing is that it is working one way and not an other...
I can t see any problem with my onfig.
sh ip vrf interfaces
Interface IP-Address VRF Protocol
Vl2 uk up
Tu2 uk up
everything is up but the counter from int tunnel 2 doesn t increase meaning the traffic doesn t go in the tunnel.
VRF-lite is a feature that enables a service provider to support two or more VPNs, where IP addresses can be overlapped among the VPNs. VRF-lite uses input interfaces to distinguish routes for different VPNs and forms virtual packet-forwarding tables by associating one or more Layer 3 interfaces with each VRF. Interfaces in a VRF can be either physical, such as Ethernet ports, or logical, such as VLAN SVIs, but a Layer 3 interface cannot belong to more than one VRF at any time
