WLC 2100 grub prompt load error
Jul 31st, 2007
I load a new image to the wlc but when restar it take me to the grub prom, somebody know how to fix this?
This shows the screen:
Launching BootLoader...
[ Minimal BASH-like line editing is supported. For the first word, TAB
lists possible command completions. Anywhere else TAB lists the possible
completions of a device/filename. ]
grub>
grub>
Overall Rating: 3 (1 ratings)
walthowd80 Wed, 08/01/2007 - 06:23
Not sure if this helps, but I read this in the controller release notes:
CSCsd52483?When you make changes in the bootloader of a 2006 controller or a Controller Network Module, the bootup process may halt, and the controller may stop responding. The controller also displays the "grub>" prompt on the console port.
Workaround: Replace the controller.
Alejandro Corte... Wed, 08/01/2007 - 06:34
Yes, i saw the same thing, and i called to cisco and they are going to replace mi WLC.
Thank you
Alejandro Corte... Wed, 08/01/2007 - 09:36
I confirm the bug:
There's a bug open on this issue, see below:
CSCsd52483
Externally found moderate defect: Assigned (A)
Controller stuck at grub> prompt
Symptom:
A WLC2006, WLC2106 or NM-AIR-WLC6 may seen to display a "grub>" prompt on the console port. It will be unable to boot the
WLC software and will not be able to operate normally.
Workaround:
Replace the hardware.
igor.nepochatov Tue, 07/22/2014 - 13:20
I had the same issue, but found different solution. In my case, CF card inside 2106 came loose. In order to re-insert it, top cover has to be removed. It is fairly easy with 3 screws on the bottom of the unit.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
