RTSP in a FW loadbalancing environment with CSM
delvauxra
We use Regular Firewall Configuration with Dual CSMs for loadbalancing.
We try to loadbalance RTSP/UDP (/TCP no problem).
The RTSP Client send a SETUP(TCP 554) to the server requesting respond using UDP port alpha
When the UDP flow come back(using port alpha) , how can i be sure that it use the same FW as the TCP flow??
Thanks in advance.
Raphael
Gilles Dufour
if you use sticky with reverse sticky, you can guarantee exactly that.
Here is an example I wrote some a while ago:
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a008020927a.shtml
Another solution is to play with predictor hash.
Gilles.
Gilles,
can't we have the same behavior by using the 'service RTSP' ?
vserver
virtual ip [tcp|udp] rtsp service rtsp
Pascal
you can, but you will dramatically reduce the performance.
I always prefer to avoid the 'service' command every time I can.
Gilles.
I read the example with sticky & reverse sticky.
Q1 : what does it occurs if there are 2 simultaneous connections from the client (Vlan499) towards the LAN server (Vlan500) and that these 2 connections pass each one by a different firewall?
Q2 : do you agree with me that this example supports only connections from customer = Vlan 499 towards server = Vlan 500 and not the server initiated traffic (= from Vlan 500) ?
Is it right to solve these issues as follow ?
CSM side Vlan499
Sticky 10 address source timeout 60
vserver SERV2FW
vlan499
sticky 60 group 10
vserver FW2SERV
vlan168
reverse-sticky 10
CSM side Vlan500
Sticky 10 address destination timeout 60
vserver SERV2FW
vlan500
sticky 60 group 10
vserver FW2SERV
vlan169
reverse-sticky 10
Pascal.
