07-31-2007 08:41 AM - edited 03-11-2019 03:51 AM
Recently, I updated the OS and ASDM on the PIX 515E. It is now OS 8.0(2) ASDM 6.0(2). When the PIX is rebooted and logged in via terminal session, the "show conn" command gives a clean connection state. If I set terminal pager 0, and then do a "show conn" connection state is corrupted, and will be corrupted every time after this. Clean reboot of the PIX and show conn works fine again until terminal pager 0 is set.
07-31-2007 12:11 PM
What's memory Do you have?
Memory Requirements
If you are using a PIX 515/515E running PIX Version 6.2/6.3, you must increase your memory before upgrading to PIX Version 8.0(2). This version requires at least 64 MB of RAM for Restricted (R) licenses and 128 MB of RAM for Unrestricted (UR) and Failover (FO) licenses. Table 1 lists the default value for the memory that ships with each security appliance and flash memory requirements for Version 8.0(2).
Table 1 Default Memory Shipped and Flash Memory Requirements
PIX Security Appliance Model Default Memory (MB) Flash Memory Required (MB)
515/515E
64
16
525
128
535
512
SYSTEMS REQUIREMENT:
07-31-2007 12:36 PM
The specs on myx PIX515E are:
Total Flash: 16MB, Total Memory: 64MB, Context Mode: Single, Firewall Mode: Routed, Encryption 3DES-AES, GTP/GPRS: Disabled, Failover: Disabled, VPN Peers: Unlimited, Max VLANs: 10, Max Physical Interfaces: 3, and License: Restricted(R).
