Jagdeep Gambhir Tue, 07/31/2007 - 10:21
Rico,
Yes you can attach Ethernet module to it and there is not need for any license or upgrade.
~JG
Jon Marshall Tue, 07/31/2007 - 11:27
I'm not sure about v7.x but i know for sure that with 6.x it depends on the license you have.
With a restricted license you can run 3 10/100 fast ethernet interfaces only. So if you want to run 4 interfaces you are going to need an unrestricted license.
Alternatively you could look to use 802.1q trunks and create logical interfaces on your pix.
Jon
srue Tue, 07/31/2007 - 11:36
keep in mind that one of the pci slots in the 515 might have a vac installed in it - giving you only one usable slot.
