Cisco Configuration tool with problem on 1800
Answered Question
Jul 31st, 2007
On the configuration tool i've got the following result:
You have successfully complete your configuration!
- Cisco 1841
- CAB-AC
- S184AISK9-12411
- MEM1800-32U64CF
- MEM1841-128U192D
- HWIC-2FE
- ROUTER-SDM
So, two things are strange:
(a)- The IOS [S18AISK9-12411XJ] is belonging to 2801 router series not to 1800 series. I checked it myself using the Cisco Feature Navigator.
UML: http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
(b) The module HWIC-2FE is not supported on the Cisco 1841 router. I checked it myself looking on module's data-sheet
UML: http://www.cisco.com/en/US/products/ps5854/products_data_sheet0900aecd80581fe6.html
I'd like to know if the Cisco Configuration tool is actually in good conditions, because there are too much in?con?sist?en?cy informations.
Related links and tools
* Cisco Configuration tool
(https://tools.cisco.com/qtc/config/html/configureHomeGuest.html)
Thank You!
Overall Rating: 3 (2 ratings)
mateuscisco Tue, 07/31/2007 - 11:12
Follow the paragraf:
(Note: The 2-port (HWIC-2FE) card is offered on the Cisco 3800 Series Routers only. The 2-port card is not supported on the Cisco 1841 nor the Cisco 2800 Series Integrated Services Routers.)
Reading this text i understand that Hwic-2FE is not supported on the Cisco 1841 (it says it), maybe the text is an old document.
mateuscisco Tue, 07/31/2007 - 11:18
Ok no problem!
So, can you help me? I need the correct information about the HWIC-2FE. Is it really incompatible on 1841?
If it is, we need to warn Cisco change the configuration tool. Other people could do the same mistake.
Tks
Edison Ortiz Tue, 07/31/2007 - 11:32
I tried to duplicate your problem and I couldn't but there is a router that comes with 2FE, so you don't need the HWIC-2FE
CISCO1841
Modular Router w/2xFE, 2 WAN slots, 32 FL/128 DR 1
CAB-AC
Power Cord,110V 1
S184AISK9-12411T
Cisco 1841 IOS ADVANCED IP SERVICES 1
MEM1800-32U64CF
32 to 64MB Cisco 1800 Compact Flash factory upgrade 1
MEM1841-128U192D
128 to 192MB SODIMM DRAM factory upgrade for the Cisco 1841 1
Included: ROUTER-SDM
mateuscisco Tue, 07/31/2007 - 11:39
The Cisco 1841 Router come with 2FE ports on its chassis, but my end-customer need more 2FE routed ports to his Laboratory.
He's a programmer, he need 4 routed ports type FE to do tests (programs/applications) by changing packets IPV4 and IPV6 between differents Lan's.
Edison Ortiz Tue, 07/31/2007 - 11:48
I see, well - as you know the HWIC-2FE is the only option then. Can I recommend looking into the 3560 8port switch for this type of scenario ?
mateuscisco Tue, 07/31/2007 - 11:57
Yes, using 3560 Layer 3 switch we can do some vlan's and change packets between them.
But what im really afraid of Configuration Tool result. As you can see the configuration "says" that the 1841 router is compatible with the HWIC-2FE (using IOS ADV IP SERVICE). Many end-custumer or Cisco Partner can do mistakes ordering this module therefore not work! We need ask Cisco to change the configurator result (if it is wrong).
I ll sugest your ideia to my end-custumer.
