jreekers Thu, 08/02/2007 - 15:00
  • Cisco Employee,
Hi Zhenning.
I don't believe it's possible. Curious though...why would you want to do this?
-Joe
zhenningx Fri, 08/03/2007 - 10:19
  • Bronze, 100 points or more
Hi Joe,
Because the help contents do not fit well in our environment. If we can not disable it, can we customrize it's contents? We want to put our own help items which are useful to our users.
thanks,
Zhenning
jreekers Fri, 08/03/2007 - 15:56
  • Cisco Employee,
Hi Zhenning.
I've spoke to some escalation folks around here, and they suggest that it wouldn't be something as easy as a plug-and-play type feature, so your best bet is to pursue this as an enhancement request to the software. You can do this through your Cisco rep, or if that's not possible, go ahead and open a TAC case and we can pursue it that way.
Sorry there's no easy "fix" for this.
-J
