PIX 515 remote VPN (PPTP) to talk to Inside network
Jul 31st, 2007
  • Silver, 250 points or more
I probably have an easy question with an easy resolution, but I cannot see it. I have a PIX 515 running 6.3(3) and I have set it up for PPTP VPDN with local authentication. I have a local pool dulling out the IP addresses for the VPN users. I authenticate fine and am given an IP address however I cannot communicate with anything on the Inside network. Am I missing something here. A second set of eyes would be helpful... Thanks.... Config below...
PIX Version 6.3(3)
name 192.168.0.4 isaserver
access-list 101 permit ip 10.10.0.0 255.255.0.0 10.10.255.0 255.255.255.0
access-list 101 permit ip 10.10.0.0 255.255.0.0 10.11.0.0 255.255.0.0
access-list 101 permit ip 10.10.0.0 255.255.0.0 10.12.0.0 255.255.0.0
access-list 101 permit ip 10.10.0.0 255.255.0.0 10.13.0.0 255.255.0.0
access-list 101 permit ip 10.10.0.0 255.255.0.0 10.15.0.0 255.255.0.0
access-list 101 permit ip 10.10.0.0 255.255.0.0 192.168.0.0 255.255.0.0
access-list 101 permit ip 10.10.0.0 255.255.0.0 10.1.0.0 255.255.0.0
access-list 101 permit ip 10.10.0.0 255.255.0.0 10.128.0.0 255.254.0.0
access-list NoNAT permit ip 10.10.0.0 255.255.0.0 10.10.255.0 255.255.255.0
access-list NoNAT permit ip 10.10.0.0 255.255.0.0 10.11.0.0 255.255.0.0
access-list NoNAT permit ip 10.10.0.0 255.255.0.0 10.12.0.0 255.255.0.0
access-list NoNAT permit ip 10.10.0.0 255.255.0.0 10.13.0.0 255.255.0.0
access-list NoNAT permit ip 10.10.0.0 255.255.0.0 10.15.0.0 255.255.0.0
access-list NoNAT permit ip 10.10.0.0 255.255.0.0 192.168.0.0 255.255.0.0
access-list NoNAT permit ip 10.10.0.0 255.255.0.0 10.1.0.0 255.255.0.0
access-list NoNAT permit ip 10.10.0.0 255.255.0.0 10.128.0.0 255.254.0.0
access-list 102 permit ip 10.10.255.0 255.255.255.0 10.10.0.0 255.255.0.0
access-list 102 permit ip 10.10.0.0 255.255.0.0 10.11.0.0 255.255.0.0
access-list 102 permit ip 10.10.0.0 255.255.0.0 10.12.0.0 255.255.0.0
access-list 102 permit ip 10.10.0.0 255.255.0.0 10.13.0.0 255.255.0.0
access-list 102 permit ip 10.10.0.0 255.255.0.0 10.15.0.0 255.255.0.0
access-list 102 permit ip 10.10.0.0 255.255.0.0 192.168.0.0 255.255.0.0
access-list 102 permit ip 10.10.0.0 255.255.0.0 10.1.0.0 255.255.0.0
access-list 102 permit ip 10.10.0.0 255.255.0.0 10.128.0.0 255.254.0.0
ip address outside xx.xx.40.2 255.255.255.240
ip address inside 10.10.1.254 255.255.255.0
ip local pool bigpool 10.10.255.1-10.10.255.10
global (outside) 1 interface
global (outside) 2 xx.xx.40.3
nat (inside) 0 access-list NoNAT
nat (inside) 1 10.10.0.0 255.255.252.0 0 0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group outside in interface outside
access-group 102 in interface inside
route outside 0.0.0.0 0.0.0.0 x.x.40.1 1
route inside 10.10.0.0 255.255.0.0 10.10.1.1 1
sysopt connection permit-ipsec
sysopt connection permit-pptp
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto ipsec transform-set toyota esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
crypto map bmw 1 ipsec-isakmp
crypto map bmw 1 match address 101
crypto map bmw 1 set peer xx.xx.132.82
crypto map bmw 1 set transform-set toyota
crypto map bmw interface outside
isakmp enable outside
isakmp key ******** address xx.xx.132.82
netmask 255.255.255.255
isakmp identity address
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash md5
isakmp policy 1 group 1
isakmp policy 1 lifetime 1000
management-access inside
vpdn group 1 accept dialin pptp
vpdn group 1 ppp authentication pap
vpdn group 1 ppp authentication chap
vpdn group 1 ppp authentication mschap
vpdn group 1 ppp encryption mppe 40
vpdn group 1 client configuration address local bigpool
vpdn group 1 pptp echo 60
vpdn group 1 client authentication local
vpdn username cisco password *********
vpdn enable outside
I am not an expert on reading config's but one thing that comes to mind is your route
I'd say that your pool BigPool is also included in this route
In order to avoid this kind of routing issues i tend to (mis) use 172.16.x.x addresses for our VPN clients and not an 192.168.x.x subnet (which we use on LAN).
Regards.
