ip source binding on cat6509
Jul 31st, 2007
Prompt how to make on 6509 ip source guard.
On 3750 I did so:
ip source binding xxxx.xxxx.xxxx vlan x ip.ip.ip.ip interface Gi1/0/1 on 65 this command does not work:
MR(config)#ip source?
source source-route
MR(config)#ip source ?
% Ambiguous command: "ip source "
ios - 72033-adventerprisek9_wan-mz.122-18. SXF7
Edison Ortiz Wed, 08/01/2007 - 05:51
  • Hall of Fame,
    Founding Member
What exactly are you trying to accomplish ?
slava_ram Wed, 08/01/2007 - 19:08
If I activate ip dhcp snooping, ip arp inspection and ip verify source on cat3750 clients received ip from a server dhcp can normally work.
If the client independently puts to itself ip accordingly cannot work. That also it is necessary for us.
But for the active equipment which stands up for 3750, I register ip source binding, differently they are not accessible.
That is it is necessary to forbid for clients to put ip, even the from dhcp, but to allow some devices to have the static address.
The same to me needs to be made on cat6509.
slava_ram Sun, 10/21/2007 - 17:42
Hi!
In itself DHCP snooping works, I cannot make static records, there is no command ip source binding.
