Can a pix 515 recieve vpn session on more than one interface
Jul 31st, 2007
Here is my Problem
I have added 4 interfaces to my pix 515e
I am trying to move all the remote offices to a VPN-T1 Dedicate for VPN and VOIP Traffic only.
On our MAIN-T1 I want to have only interoffice VPN and VOIP Traffic.
When i try to move one of the remote offices from MAINT1 to VPNT1 I get host not found X.X.X.X/500 Peer info not found.
I am using the same IKE Key since all of the remote offices are on cable/dsl.
I listed the configs below any help would be great..
mchin345 Mon, 08/06/2007 - 13:44
If you connect a computer directly to the inside interface of the PIX Firewall with Ethernet to test Telnet access, you must use a cross-over cable and the computer must have an IP address on the same subnet as the inside interface. The computer must also have its default route set to be the inside interface of the PIX Firewall.
