about pppoe password
Jul 31st, 2007
if i was using CLI to do:
ppp chap password <password>
how can i use something i can recognize, and still encrypt it? if i do a "ppp chap password 0 pw", then my password "pw" is open to viewing, but if i do "ppp chat password 5 pw", "pw" wouldn't be acceptable, so how can i use something i can remember and still mask the actual password?
winstoncheng Wed, 08/01/2007 - 12:47
This would be done by just entering:
password encryption aes
at the config?
And it's one command for the entire router, not just the Dialer0 interface?
mohammedmahmoud Tue, 07/31/2007 - 22:44
hi,
The only 2 accepted values for password encryption (in the display) is 0 (not yet encrypted - default) and 7 (and here you must enter the password in the encrypted form), but note that once you enabled service password-enryption, the password will be encrypted when displayed, even if you've entered it as unencrypted "0".
HTH,
Mohammed Mahmoud.
