VOIP Home lab
Jul 31st, 2007
quick question, I'm also looking into a voip home lab. Does callmanager 4.x requires a license on vmware?
So the ip phones do not require licenses at all? How about if integrating the ip phone to lets say my Vonage box?
If license is an issue with callmanager 4.x, how about running callmanager express 4.x on a 2611xm router? I have the IOS and CM express 4.x softwares, haven't installed yet...does CM express requires a license?
Has anyone got their Vonage box to work with CM using the ip phones? I think it can be done...but I'm not really sure what to do.
thanks
opers13
dford333 Mon, 08/06/2007 - 05:39
Callmanager always requires a user license for the # of phones it will support,
Licenses
You must purchase a base Cisco Unified CME feature license and phone user licenses that entitle you to use Cisco Unified CME.
I have installed CM, Unity and CME w/o licenses but runs limited support as far as how many devices I can connect
Vonage uses and adapter to connect to there network with is SIP based
