is-is route selection in routing table
Answered Question
Jul 31st, 2007
hi every one
i have a question about route selection for routing table. A little illustration might make help.
router " A" is L1/L2 . " A" is learning route 1.1.1 from L1 neighbour with metric 4 and from L2 neighbour with metric 4.
which one will get selected?
second scenario:
router "A" is now learning 1.1.1.1 from L1 neighbour with metric 4 and from L2 neighbour with metric 5.
scenario # 3
R1(L2)------------------------R2(L1/L2)
router 1 is connected via serial int to router 2
Router 2 is L1/L2 while router 1 is L2
routing table at router 2 looks as shown below:
c 1.1.1.0/24 is directly connected E0
IL1 2.2.2.0/24[15/20] via 3.3.3.3 e2
will router2 will exchange the route 2.2.2.0 learned by L1 process with router1?
thanks every one.
Correct Answer by etienne.basset about 9 years 6 months ago
hello
scenar 1 &2
L1 routes are prefered over L2 routes
scenar 3
yes
Etienne
Overall Rating: 5 (1 ratings)
Correct Answer
etienne.basset Wed, 08/01/2007 - 01:03
hello
scenar 1 &2
scenar 3
yes
Etienne
zeeshanr202 Wed, 08/01/2007 - 08:25
hi every body
i just read the tcp/ip guide jeff Doyle.According to the book, router 2 will exchange the 2.2.2.0 as L2 route with R1.
R1 will install the route as L2 2.2.2.0.
hope it might help others with the same questions.
thanks
