Command : Clear Buffer Failures
Aug 1st, 2007
  • Gold, 750 points or more
Hello All,
When i execute "show buffers" command in my 7206 VXR Router i see huge amount of Failures, Misses, etc., in Small, Middle and Big Buffers.
Can anyone provide / tell me the Command to Clear these Buffer Failures errors in Router.
I am aware this requires reboot but i missed the command what to execute.
Thanks in Advance for Help
Best Regards,
Guru Prasad R
Danilo Dy Wed, 08/01/2007 - 00:28
  • Blue, 1500 points or more
Just reboot the router and it will clear the buffer.
Dandy
dbakula01 Fri, 08/24/2007 - 04:47
you can't clear them, just reboot like the guy above said is the only way
