08-01-2007 12:28 AM - edited 03-03-2019 06:07 PM
I'm testing QoS strategy on test network and I'm using wireshark to get result on my test scenario. I'm testing video broadcast across a network made with three 2600 router and 2 BPS2000 (Nortel switch) at the boundary.
PC1----BPS2000(switch)-----router1-----router2-----router3----BPS2000(switch)-----PC2.
I'm using VLC to do unicast video streaming across my network, and I use Wireshark at each end of my network to have measure.
I absolutly need measure such as max_bw, max_burst... provide by Wireshark. Unfortunatly Wireshark provide its statistic in the only case where I do multicast streaming and not unicast streaming.
Having absolutly no knowledge about multicast, I've tried to do multicast streaming instead of unicast streaming.
I've read cisco document about multicast streaming, but I don't succeed to do my musticast streaming.
I did this on each interface of my routers :
Router(config)# ip multicast-routing
Router(config-if)# ip pim dense-mode
On router1, where I want to create my multicast group I did this
Router1(config-if)# ip igmp join-group 224.1.1.1
The configuration I have made don't work. Do you know how can I do to do my multicast streaming from PC2 to PC1.
How can I do to create my multicast group?
Is something to do on the switch?
08-01-2007 01:16 AM
Before we go into the bowels of multicast routing the first thing we have to ascertain is that your source PC2 is actually using VLC to stream the video content to a multicast address. If it is then running wireshark on PC2 should show that it is sending information to 1 or more multicast groups [224.x.x.x - 239.x.x.x]. Can you confirm this?
Secondly, you need to confirm that the 3 2600 routers are PIM neighbours of each other. I'm assuming that the link between the routers are WAN links. In that case running show ip pim nei on router1 should show that router2 is its PIM neighbour, running show ip pim nei on router2 should show that router1 & router3 are its PIM neighbours and finally running show ip pim nei on router3 should show that router2 is its PIM neighbour. can you confirm this?
In order to force router1 to send the traffic to PC1 [your receiver] use ip igmp static-group
You can then run show ip mroute
Sorry this is a bit lengthy but it should get you on your way.
08-01-2007 01:24 AM
One other thing, make sure that all routers have routers to the LAN subnet the PC2 resides on, if not the RPF check will fail
08-01-2007 06:16 AM
Hi cjnwodo
thank you for your response.
First, I confirm that VLC stream the video content to a multicast address.
Secondly ip pim nei give the good result on all the router.
Unfortunaltly when I start video streaming from PC2, transmission doesn't work. I can see activity on router1 (led blinks) but only on this one. I deduct that this router can't succeed to find out where it must route packets with 224.1.1.1 destination address.
You can find in attachment my network scheme and addressing and the running config of my three routers
Here is the result from
ip igmp group show :
router1#show ip igmp group
IGMP Connected Group Membership
Group Address Interface Uptime Expires Last Reporter
224.0.1.40 FastEthernet0/0 18:44:43 00:02:34 192.168.1.1
239.255.255.250 FastEthernet0/0 18:46:51 00:02:26 192.168.1.3
router2#show ip igmp group
224.0.1.40 FastEthernet0/1 00:22:44 00:02:32 192.168.3.2
router3#show ip igmp group
224.1.1.1 FastEthernet0/1 19:21:54 00:02:03 192.168.4.1
224.0.1.40 FastEthernet0/0 00:20:48 00:02:30 192.168.3.2
and here is the result from the following command show ip mroute
/////////////router1////////////////////////
(*, 224.0.1.40), 20:58:47/00:02:35, RP 192.168.1.1, flags: SJCL
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
FastEthernet0/0, Forward/Dense, 20:56:38/00:00:00
(*, 239.255.255.250), 20:58:46/00:02:39, RP 192.168.1.1, flags: SJC
FastEthernet0/1, Forward/Dense, 02:29:41/00:00:00
FastEthernet0/0, Forward/Dense, 20:56:37/00:00:00
/////////////router2(core)////////////////////////
(*, 224.0.1.40), 04:30:53/00:02:34, RP 0.0.0.0, flags: DCL
FastEthernet0/0, Forward/Dense, 02:30:42/00:00:00
FastEthernet0/1, Forward/Dense, 04:30:01/00:00:00
/////////////router3////////////////////////
(*, 224.1.1.1), 21:36:56/stopped, RP 0.0.0.0, flags: DC
FastEthernet0/1, Forward/Dense, 02:28:00/00:00:00
FastEthernet0/0, Forward/Dense, 04:31:37/00:00:00
(*, 224.0.1.40), 21:37:52/00:02:28, RP 0.0.0.0, flags: DCL
08-01-2007 06:41 AM
Could you check if there is ttl setting for the video stream with the VLC software. You will need to make sure it has a ttl of at least 3 to reach PC1.
You should not need the "ip igmp join..." on R1 as this is pim dense mode so you should see the 224.1.1.1 group on all your routers anyway regardless of whether anything wants to receive the video stream.
Also could you confirm whether or not you have turned IGMP snooping on on the switches.
Jon
08-01-2007 06:56 AM
thank you very much, for your suggestion, I put the ttl to 4 and video stream has worked.
