WS-X6148A-45AF coming up as unknown
Aug 1st, 2007
We have a 6509-E with SUP720-3B running 12.2(18)SXD7b and the above module is not coming on-line. Below is a show module and the result if when the module was inserted into slot 9
Router>sh module
Mod Ports Card Type Model Serial No.
2 48 48 port 10/100/1000mb EtherModule WS-X6148-GE-45AF SAL1105G072
4 48 unknown FRU type (major = 0x6003, mino WS-X6148A-45AF SAL1052C1V6
00:05:20: %C6KPWR-SP-4-UNSUPPORTED: unsupported module in slot 9, power not allowed: Unknown Card Type.
I have researched on CCO against the hardware, and the suggested minimum software is the one we are running and also 12.2(17d)SXB11a. We have tried the second code and get the same results.
Has anyone else experienced problems with this card, or know of a resolution?
Thanks in advance.
Shaun
Jon Marshall Wed, 08/01/2007 - 02:25
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Shaun
What power supplies are you running. Can you post the output of a "sh power".
It may well be you do not have enough power to power up that card and the 6500 will start at slot 9 and work backwards in terms of modules it disables.
Jon
swakelen Wed, 08/01/2007 - 02:27
Thanks for the replay. PSUs are 6000W and we know that we have enough power. Just found another reference on CCO that states we need 12.2(18)SXF, so that conflicts with what we saw yesterday! :(
Just downloading the latest version, and will see how it goes.
Shaun
