G.703 to V.35 configs
Aug 1st, 2007
I have a LL (2mbps) one end of which is having V.35 o/p and the far(remote) end it is G.703 o/p.These are the o/p from the modem. Would they work with each other....
sample config would be more helpful...
Overall Rating: 4 (2 ratings)
Paolo Bevilacqua Wed, 08/01/2007 - 02:14
  • Hall of Fame,
    Founding Member
Yes, they will work. On the G.703 side, uncer controller configure channel-group with as many timeslots you are given. Beside this there is no special configuration, just a normal serial line like any other.
sagar.shetty Wed, 08/01/2007 - 02:19
I am having smart serial card at V.35 side..
Which of the following would be better for the G.703 side...
VWIC-1MFT-E1
VWIC-1MFT-G703
I would only have just a plain E1 data link
Paolo Bevilacqua Wed, 08/01/2007 - 03:46
  • Hall of Fame,
    Founding Member
VWIC-1MFT-E1 should be fine. The other type is only when you have unframed link running at 2.048 mbps. And even if it is that what you have. MFT-E1 will work anyway, but at 1.948 mbps.
Paolo Bevilacqua Wed, 08/01/2007 - 04:18
  • Hall of Fame,
    Founding Member
Small correction: 31 timeslots is 1.984, not 1.948 Mbps.
Thanks for the rating and good luck!
