PIX Boot Problem
Aug 1st, 2007
I have PIX 515E Firewall when I statrt it the following message appear in Hyper Terminal.
CISCO SYSTEMS PIX FIREWALL
Embedded BIOS Version 4.3.207 01/02/02 16:12:22.73
Compiled by morlee
64 MB RAM
PCI Device Table.
Bus Dev Func VendID DevID Class Irq
00 00 00 8086 7192 Host Bridge
00 07 00 8086 7110 ISA Bridge
00 07 01 8086 7111 IDE Controller
00 07 02 8086 7112 Serial Bus 9
00 07 03 8086 7113 PCI Bridge
00 0D 00 8086 1209 Ethernet 11
00 0E 00 8086 1209 Ethernet 10
00 11 00 14E4 5823 Co-Processor 11
If anyone can guide me because my network is down for a few days
srue Wed, 08/01/2007 - 04:10
  • Blue, 1500 points or more
Is that were it stops? does it keep rebooting continuously? Or does it go into rommon mode?
vraghu Wed, 08/01/2007 - 04:17
Yest it stop even i can not go rommon mode by disturbing it by ESC or Break
vraghu Wed, 08/01/2007 - 20:27
Is there anyone to help me. The message which I posted the firewall stack after that. I cannot go to any mode. Please if anyone can help me.
Thank you in advance
JORGE RODRIGUEZ Thu, 08/02/2007 - 17:20
  • Green, 3000 points or more
as indicated by zubairjalal, you will have to rma it hoping you have a backup of the config , also it would be recomended to deploy a ASA failover solution, with this solution your network will not be down.
zubairjalal Thu, 08/02/2007 - 01:55
  • Bronze, 100 points or more
I think you should proceed with a RMA.
regards
Zubair
