enabling vtp version 3
Aug 1st, 2007
I am trying to enable vtp version 3 on my redundant 6505E's running glbp and are having some trouble. It tells me I need to use the command "set spantree macreduction enable" but this command doesn't work when I type it. Is there something I'm missing?
Overall Rating: 4 (2 ratings)
Jon Marshall Wed, 08/01/2007 - 05:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi William
As far as i know VTP version 3 is only supported on CatOS ver 8.1 and later.
Jon
william.briere Wed, 08/01/2007 - 05:53
Forgive the question... But should I be using CatOS or IOS? I'm really unsure about the benefits or drawbacks of each.
ankbhasi Wed, 08/01/2007 - 05:56
  • Cisco Employee,
Hi William,
I will say IOS as there is more focus towards IOS and redundancy like SSO with NSF is possible in IOS only. Also it is easy to have one single interface to manage switch as well as router where you have 2 different OS to be managed in CATOS (Hybrid Mode).
Ankur
*Pls rate all helpfull post
william.briere Wed, 08/01/2007 - 05:58
So you say that I should be running IOS if I have two 6500's with one 720-3b sup in each chassis running GLBP?
How would I be able to have VTP server redundancy in this case?
Just thought I would ask :)
Jon Marshall Wed, 08/01/2007 - 06:02
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
William
You can still make both core switches VTP servers for redundancy.
Jon
sundar.palaniappan Wed, 08/01/2007 - 05:56
  • Green, 3000 points or more
I would recommend using IOS because that's the way Cisco is heading. There are definitely some advantages using CatOS image but I wouldn't be suprised if all/most Cisco equipment might support only IOS in the future.
Sundar
Jon Marshall Wed, 08/01/2007 - 06:00
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Sundar / Ankur
Uncanny how we happen to be posting at exact same time :)
Jon
Jon Marshall Wed, 08/01/2007 - 05:57
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
If you run CatOS on the switch then you will still need to run IOS on the MSFC.
Nowadays i think it's fair to say IOS would be the first choice for the 6500 although we do run CatOs on some of our access-layer switches as we have no need for IP routing on these switches.
If your switch is doing inter-vlan routing etc. then unless you have a specific feature you need that is only supported on CatOS i would recommend using IOS.
Jon
