2600xm routers support MPLS and QoS?
Answered Question
Aug 1st, 2007
Im going for the new CCNP and I have a few 2600xm series routers. Can I use it to study MPLS and QoS topics?
Correct Answer by mohammedmahmoud about 9 years 2 months ago
I've used "c2600-j1s3-mz.122-15.T12.bin" on a Cisco 2611 with 64M DRAM.
Please use Cisco Feature Navigator to find the appropriate IOS image to support the features you require on the platform you require.
Mohammed Mahmoud.
Overall Rating: 5 (3 ratings)
mohammedmahmoud Wed, 08/01/2007 - 06:01
Generally yes you can, please do check the feature navigator for the proper IOS:
P.S you might need to upgrade your DRAM/Flash, and i've even got once into a scenario where i booted my router over tftp to get the IOS.
Mohammed Mahmoud.
network27 Wed, 08/01/2007 - 08:03
Thanks Mohammed. My routers have 132MB RAM and 32Mb flash, i guess that enough.
network27 Wed, 08/01/2007 - 17:18
Hi Mohammed,
Which software feature set are you using?
Ive tried v12.4 enterprise plus and IP plus and advanced security IOS but they did not support MPLS
network27 Thu, 08/02/2007 - 00:23
Thanks Mohammed. You're a good man. If i could rate you out of 10, i would give you 11:)
mohammedmahmoud Thu, 08/02/2007 - 00:31
Hi Bao,
You are more than welcomed :) and thanks for using the rating system :)
Please never hesitate to come back for any further questions, and good luck with your CCNP.
Mohammed Mahmoud.
javierfcastillo Sat, 10/27/2007 - 13:51
Hi mohammed! i'm trying to do a lab at my university implementing MPLS. I have routers cisco 2610 series. This is my configuration:
Cisco2600-2(config-if)# ip route-cache cef
Cisco2600-2(config-if)# mpls label protocol ldp
Cisco2600-2(config-if)#mpls ip
My problem is that i can't use te "set mpls experimental topmost " command at the policy-map. My options are:
QoS policy-map class configuration commands:
bandwidth Bandwidth
compression Activate Compression
drop Drop all packets
exit Exit from QoS class action configuration mode
no Negate or set default values of a command
police Police
priority Strict Scheduling Priority for this Class
queue-limit Queue Max Threshold for Tail Drop
random-detect Enable Random Early Detection as drop policy
service-policy Configure QoS Service Policy
shape Traffic Shaping
My version of the IOS is:
IOS (tm) C2600 Software (C2600-TELCO-M), Version 12.3(15b), RELEASE SOFTWARE (fc1)
wich version do i need to run this command and configurations?? Any information will help. Thank you very much. Best regards!!
