PIX
Answered Question
Aug 1st, 2007
Is there a command to find out how long the PIX has beem up and running? In routers sh ver shows how long the router has been up.
Correct Answer by Jon Marshall about 9 years 5 months ago
Output from sh ver on pix running 6.x
pix-1(config)# sh ver
Cisco PIX Firewall Version 6.3(2)
Compiled on Tue 08-Jul-03 10:56 by dramnath
dramnath-pix-1 up 2 hours 51 mins *** <- this bit
Hardware: PIX-515, 32 MB RAM, CPU Pentium 200 MHz
Flash i28F640J5 @ 0x300, 16MB
BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0:ethernet0:address is 0003.e300.1552, irq 10
1:ethernet1:address is 0003.e300.1553, irq 7
2:ethernet2:address is 0090.273a.1611, irq 11
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Enabled
Maximum Physical Interfaces:3
Maximum Interfaces: 5
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has a Restricted (R) license.
Serial Number:5 (0x5)
Running Activation Key:0x2b2bcadc 0xbff80f39 0x71c6c743 0xa06ee021
Configuration last modified by enable_15 at 20:14:25.505 UTC Thu Jul 24 2003
dramnath-pix-1(config)#
Do you not see this on your pix 501 ??
Jon
Overall Rating: 5 (1 ratings)
saidfrh Wed, 08/01/2007 - 07:15
Jon,
The PIX 501 nor the ASA5505 shows the "uptime" on the command of sh ver.
Correct Answer
Jon Marshall Wed, 08/01/2007 - 07:26
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
Guards: Enabled
Jon
