ASA5505 not responding to telnet session
Answered Question
Aug 1st, 2007
We have a ASA5505 at a branch office for IPSEC VPN to main office. Telneting to the ASA5505 gives a message "Could not open connection to the host, on port 23: Connect failed". The branch office has access to the internet. Any suggestions to be telnet to above firewall would be appreciated.
Correct Answer by jerrytozhang about 9 years 2 months ago
Using ssh to remote acccess your ASA box is always best way.
You can download and install a SSH client to your PC,like Putty, it's a free software, you can get it at
Or you can buy a SecureCRT if you want more powerful SSH client.
Overall Rating: 5 (2 ratings)
Jon Marshall Wed, 08/01/2007 - 06:51
Are you trying to use telnet to the outside interface of the ASA ?.
You can't use telnet to connect to the outside interface of an ASA. You need to either
1) Use ssh
2) use telnet but within an IPSEC tunnel.
acomiskey Wed, 08/01/2007 - 07:06
You can also telnet to the inside interace over the tunnel with the command management-access inside.
saidfrh Wed, 08/01/2007 - 07:17
Jerry, Thanks Putty allowed access to the device.
