08-01-2007 11:09 AM - edited 03-14-2019 10:53 PM
In CallManager 5.1, do you enter the subscribers MAC address when registering the second server PAK file or the publisher? Have already done one for the publisher. Also, do you have to enter the license file separately on the sub?
08-01-2007 11:36 AM
Hi Chris
actually you buy what's called a node license for each server (Pub and subscriber), now what you get is a pak for Pub and a pak for each subscriber, when u go to www.cisco.com/go/license you are required to enter pak for the Pub and publisher' MAC to get the license file for the publisher
you also are required to enter the pak for the subscriber and also the publisher' MAC to get the license file for the subscriber.
once you get the two files u have to upload both in the Publisher admin page, actually all your admin work is on Pub, and all are replicated to Sub.
hth
/majdi
08-02-2007 03:12 AM
when you try to register the PAK of the 2 node licenses, use only the MAC address of the Publisher server.
cheers!
