vpn configuration problems 2621xm and vpn client
Aug 1st, 2007
I'm trying to configure my home cisco 2621xm to accept vpn connections. I've used many cisco pdf documents and they all same almost the same so I've done my configuration using these documents.
now I just can't get past this error message I'm getting and I have no idea why this is happening.
any ideas to help me get past this step, I'm really stuck here.
also, I've tried vpn client version 5 and 4.8
cisco ios version is:
Cisco IOS Software, C2600 Software (C2600-ADVIPSERVICESK9-M), Version 12.4(16), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 20-Jun-07 05:48 by prod_rel_team
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
vision-router-01 uptime is 2 hours, 53 minutes
System image file is "flash:c2600-advipservicesk9-mz.124-16.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2621XM (MPC860P) processor (revision 1.0) with 127308K/3764K bytes of memory.
Processor board ID JAD06350FM7
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
32K bytes of NVRAM.
49152K bytes of processor board System flash (Read/Write)
here is my the config that's vpn related
aaa authentication login MYTAC group tacacs+ local enable
aaa authorization network GROUPAUTHOR local
username someuser password 0 somepassword
crypto isakmp policy 5
encr aes 256
authentication pre-share
group 2
crypto isakmp keepalive 10 periodic
crypto isakmp client configuration group VTELVPN
key cisco123
domain xyz.com
crypto ipsec transform-set VTELSET1 esp-aes esp-sha-hmac
crypto dynamic-map VTELDYNAMAP 10
set transform-set VTELSET1
set identity thisrouter-01
crypto map VTELCLIENTMAP client authentication list MYTAC
crypto map VTELCLIENTMAP isakmp authorization list GROUPAUTOHOR
crypto map VTELCLIENTMAP client configuration address respond
crypto map VTELCLIENTMAP 10 ipsec-isakmp dynamic VTELDYNAMAP
interface Dialer1
ip address negotiated
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
no cdp enable
ppp chap hostname xxxxxx
ppp chap password 7 hahahahohoho
ppp pap sent-username xxxxxx password 7 hahahahohoho
ip local pool VTELVPNPOOL
spremkumar Wed, 08/01/2007 - 23:49
Can you try assigning a static ip to the dialer interface and try checking out the vpn connectivity ?
pamirian76 Thu, 08/02/2007 - 05:30
this did not change a thing.
and no I can not get a static ip but I doubt it has anything to do with it.
