Opt out of queue and leave message
Answered Question
I want to edit a script to place someone in queue if all agents are busy. Then play hold music for 20-30 seconds between a prompt that says "We are busy, please continue to hold, or press # to leave a message for our agents to return."
So the question is what kind of play prompt will allow me to look for a key punch for 5-8 seconds and then go on to the queueloop? I don't want the "are you still there?" prompts that occur during the timeouts, I just want it to go on as if no input was needed.
Correct Answer by dchumbley about 9 years 8 months ago
Change the maximum retries to 0 in the Menu or GetDigitString steps. Then it won't play the are you still there message
Overall Rating: 5 (1 ratings)
Correct Answer
dchumbley Wed, 08/01/2007 - 12:52
