350 series bridge *only*
Aug 1st, 2007
Have two Cisco 350 Series Bridge (o/s 12.03T)radios, using them as wireless bridge between two buildings. I had *thought* that I had gone into the GUI and set them to be bridges only and not allow client connections. However, have just discovered that they do allow client connections, and I can't find the screen where I thought I had done that. Am wondering, should I configure both units to be "client/non-root"? Both are connected to wired LAN at their respective ends, but neither should allow a connection to any device except the other end of the bridge. Any help?
Thanks!
t
