routing issue
bma
we are running netscaler between vlan140 and vlan150 and netscaler has vlan140 and 150 setup. Netscaler ip and vserver ip are in the vlan150, web server ip is in the vlan140.No problem with vserver ip to access web server. But when setup a vserver to point to inside web server in the network vlan100
and cannot see any page. Using Ethereal to moniting, traffic stop in the vserver ip address, not continue. How to setup a routing netscaler to cisco route?
ben
smalkeric
Level 6
Level 6
The configuration is for SCAs in nontransparent proxy mode with connection in one-port mode. In nontransparent mode, the SCA uses the SCA IP address as the source for plain-text connections to the web servers. Use two different VLANs/IP subnetworks for the SCAs and the web servers; one subnetwork is for all SCAs, and a separate subnetwork is for all web servers. If you place both farms in the same Layer 2 (L2) domain, source Network Address Translation (NAT) is necessary. Source NAT guarantees that packets return to the CSM and that the Catalyst hardware does not simply L2 switch the packets.
Thanks. Issue is with netscaler usip, after disable usip with vserver, it's fine to access web server.
Ben
