EIGRP and BGP mutual redistribution.
Aug 1st, 2007
I am doing mutual redistribution with the following:
router eigrp 10
redistribute bgp 64586 metric 155000 10 255 1 4470 route-map bgp-to-eigrp
! redist bgp routes with route-map and metric
router bgp 64586
no synchronization
bgp log-neighbor-changes
redistribute eigrp 10 route-map eigrp-to-bgp
neighbor remote-as 209
neighbor ebgp-multihop 2
neighbor update-source Loopback0
neighbor weight 40000
no auto-summary
!redist eigrp routes with route-map
access-list 1 permit
! rtdallas-7206
access-list 2 permit
! rtapple
access-list 3 permit
! rtlb
access-list 4 permit
! rtbrun
access-list 5 permit
! rteb
access-list 6 permit
! rtdal-fg
access-list 7 permit
! rtwest
access-list 8 permit
! rt6513-nw
access-list 9 permit
! rt6513-d
access-list 10 permit
! rt6513-3
access-list 11 permit
! rtgac4
access-list 12 permit
! rtgac-old
route-map eigrp-to-bgp deny 10
match ip next-hop 1
route-map eigrp-to-bgp deny 11
match ip next-hop 2
route-map eigrp-to-bgp deny 12
match ip next-hop 3
route-map eigrp-to-bgp deny 13
match ip next-hop 4
route-map eigrp-to-bgp deny 14
match ip next-hop 5
route-map eigrp-to-bgp deny 15
match ip next-hop 6
route-map eigrp-to-bgp deny 16
match ip next-hop 7
route-map eigrp-to-bgp deny 17
match ip next-hop 8
route-map eigrp-to-bgp deny 18
match ip next-hop 9
route-map eigrp-to-bgp permit 30
set tag 10
!set tag to deny later in redist to bgp
route-map bgp-to-eigrp deny 10
match tag 10
!deny routes learned from eigrp
route-map bgp-to-eigrp permit 20
set tag 64586
set ip next-hop
This seems to work except for routes in EIGRP at another router.
rt6513-3 is running both protocols and doing the redistribution. It also has
the external BGP session. On this router the EIGRP entry for the BGP
learned route is
P, 1 successors, FD is 18944, tag is 64586
via Redistributed
and the route table entry is
6513-3#sh ip ro
Routing entry for
Known via "bgp 64586", distance 20, metric 0
Tag 209, type external
Redistributing via eigrp 10
Advertised by eigrp 10 metric 155000 10 255 1 4470 route-map bgp-to-eigrp
bgp 64586 (self originated)
Last update from 01:20:42 ago
Routing Descriptor Blocks:
*, from, 01:20:42 ago
Route metric is 0, traffic share count is 1
AS Hops 2
Route tag 209
When I go to another router that is running EIGRP only (rt6513-2n) the EIGRP
topo entry is
P, 1 successors, FD is 864000
via, Vlan92
via, Vlan92
The metric is now the same as the metric for the other route that is learned
natively in EIGRP from a 3rd router (rtgac).
I changed the delay on rtgac to try to force the BGP learned route to have a
higher metric, but what happened is both routes have the new higher metric in
before the change they both showed 858880.
The metrics for these should be calculated from these values
rtgac rt6513-3
155000 44210
10 20
255 255
1 5
4470 1500
If I shut down the interface for the route on rtgac I get this on (6513-2n)
P, 1 successors, FD is 19200, tag is 64586
via, Vlan92
If I no shut the interface it goes back to this
via, Vlan92
via, Vlan92
Pavel Bykov Fri, 08/03/2007 - 05:43
Please post the topology. I don't quite understand where the other router connects to.
You have posted the configuration from one router only. Is the configuration same on the other routers?
I cannot help you exactly without topology and all of the configuration, but try redistributing without route-maps, and then gradually add route-map complexity.
This config seems ok, if you're really blocking all the next hops you need to block, and not the ones you don't want.
