How to configure stickiness on ACE20 ?
Aug 1st, 2007
Config attached....
I have set-up 2 ace20's for SLB which works fine, however I am struggling to understand how to configure stickiness in the way I want to. I want any user on the network whom connects to any of the 5 rservers to have a sticky time of 60 minutes as requested by the application vendor, the app is http.
The network is subnetted and all subnets fall within the ranges 172.16.0.0/12 and 192.168.0.0/16. Can any one help me with the sticky configuration. As you can see from my config I started to configure this but do not quite understand how to classify the traffic and associate it with the serverfarm.
I am new to content switching.
Paul Tribe (CCNA, CCMP, CCSP)
Technical Analyst
Nottingham City Council (UK)
Tel - +44 (0)115 915 4119
m.mcconnell Mon, 08/06/2007 - 11:01
You have stickiness configured but it has not been applied. Try this:
policy-map type loadbalance first-match L7_VIP_LB_ORDER_POLICY
class class-default
sticky-serverfarm Carefirst
Note the change in the last line. This applies the sticky rule. Hope this helps.
Dan Smith Thu, 08/09/2007 - 07:45
Thanks I had eventually worked it out but you are absolutely right.
