spremkumar Wed, 08/01/2007 - 22:17
  • Red, 2250 points or more
Generally its recommended to subscribe 10 Mbps capacity through ethernet where you have the option have scalability in the future...
I dont think so that you will be able to get a 10meg link on a wic card from your telco...
You may have to go for DS-3 card to have the same or as i mentioned in the begining it will be on ethernet..
regds
pbhatkoti Thu, 08/02/2007 - 01:01
If you are serious about using serial ports why don't u use HSSI port?
I think the standard of any serial card (except HSSI) is 2 megs. Cisco's proprietry serial ports (v.35, X.21, ..) supports more than 2 megs. I have tested upto 8 megs.
Pushkar bhatkoti
