cisco LMS cannot monitor wireless controller 4402 and ASA 5520
Answered Question
Aug 1st, 2007
i heard that LMS can not monitor all wireless controller and ASA. is that true? i am using LMS version 2.6 and try to monitor the inventory of APs which are controlled by wireless controller 4402.but i cannot have information about the wireless controller. i checked the snmp string and they seems correct. any idea? appreciate all the help.
Correct Answer by Joe Clarke about 9 years 5 months ago
I do not. I do know they are not on the immediate roadmap.
Overall Rating: 4.5 (3 ratings)
Joe Clarke Wed, 08/01/2007 - 22:37
LMS 2.6 does not support any of the WCS devices, but it does now support all ASA devices provided you have the latest RME 4.0.5 device package updates.
Martin Ermel Wed, 08/01/2007 - 23:19
do you know if it is on the roadmap to integrate the WCS devices with LMS 2.6 or will they be supported with LMS 3.0?
Correct Answer
Joe Clarke Thu, 08/02/2007 - 08:52
thetnaing00 Wed, 08/01/2007 - 23:31
thanks for your fast reply. one more thing is you said all WCS. is that mean includig wcs, wlc and all?
