CCM Gateway setup.
Aug 1st, 2007
Hi All,
I am using CCM 4.0 and my VG is 3745 router. Initially I had only one Voice Interface Card in my VG 3745 router for 23 channels/ports.
Now I installed one more Voice Interface Card in my VG 3745 router for more 23 channels/ports.
How can I change update my current CCM gateway setup to increase the Voice Interface Card selection?
Majdi Harb Thu, 08/02/2007 - 00:35
  • Silver, 250 points or more
i assume u have configured ur new gateway for the new T1 in the GW part, now in ur CCM admin page, u have to add this gateway, go to Device -> Gateway -> ur 3745 gateway -> besides subunit u will find like two ports -> configure the new gateway (the new t1 card) settings.
then under call routing - route hunt - route group add this new port (new t1) in ur existing route group
now calls will be circulated (default) between the two t1's
hth
/majdi
edison_abad Thu, 08/02/2007 - 02:51
alternative (preferred if you are using H323 protocol in your VG), use Trunk group configuration:
1. at the global, enter: trunk group
2. under trunk group config, choose the scheme: hunt-scheme (just select the hunting selection per trunk group member, type ? to list)
3. optionally, you can limit the number of calls in this trunk group: max-call voice
4. once the you defined a trunk group, apply it into the dial-peer (say, going to PSTN): trunk-group . the preference will determine the order of VG's selection. the lower the most preferred.
Majdi Harb Thu, 08/02/2007 - 02:55
thanks for remark edison, yes i assumed MGCP GW.
Greetings
/majdi
examples20001 Thu, 08/02/2007 - 04:58
hi,
I am using H323 between my VG and CCM.
Is their any config need to done in CCM other than in VG router?
Attached file is the VG config.
edison_abad Thu, 08/02/2007 - 05:44
no other config in ccm required (assuming the 2 T1s have the same expected digits when receiving/sending digits). it uses the existing h323 gateway device in ccm and all existing Route patterns pointing to your gateway.
hope this help.
Cheers!
edison_abad Thu, 08/02/2007 - 05:54
from your configuration, the outgoing dial-peers should be okay. by adding preference command to your second dial-peer, VG will forward all calls to port 1/0. if all ports are busy, h323 gateway will automatically use the T1 in 2/0.
by using trunk group hunt scheme, you can manipulate the selection of the ports.
examples20001 Fri, 08/03/2007 - 04:22
Currently my CCM is showing as 23 channels for both of my VG routers, but actually I have 46 channels in each (92 channels total).
Why the CCM is using only the 23 channels of primary VG router?
examples20001 Sun, 08/05/2007 - 22:36
From my CCM report status, it is showing only 23 channels for my VG router, but actually my VG router has got 46 channels (46*2=92 channels total).
Why is it so? Is any config need to done in CCM?
