ccme, call-forward with sip
Answered Question
Aug 1st, 2007
im running callmanager express 4.1 with sip trunk to ITSP.
now the provider complaint that i was calling out with numbers that where not mine, and that screw up his billing on me so hi threaten to shut my account down... I discovered that it did so when i call-forward to an external number like my cellphone, it uses the callers nr and make a call with that to my cell. I solved this by making a tranlation rule that makes all outgoing numbers transate to one of mine numbers.
and now i wonder if this can be made in a other better way, without the translation rule?
Grateful for any help!
//Kristoffer
Correct Answer by paolo bevilacqua about 9 years 11 months ago
Translation-rule is the proper way. And your ITSP should learn something from traditional telcos. If you call with the correct or wrong number, be sure you are billed anyway :)
Overall Rating: 4 (2 ratings)
Correct Answer
paolo bevilacqua Thu, 08/02/2007 - 01:01
  • Hall of Fame,
    Founding Member
krille_com Thu, 08/02/2007 - 01:43
yeah I thought so to, but am new at this telephony stuff so i didn?t want to argue... :)
paolo bevilacqua Thu, 08/02/2007 - 02:57
  • Hall of Fame,
    Founding Member
When I've answered before I must have a been a little sleepy. There is an easier way: configure "clid" under DP.
Thanks for the nice rating and good luck!
