SIP Inspection
Aug 1st, 2007
HI,
I have ASA 5510 withc csc module, i need to enable sip trafic (Udp 5060), the sip inspected by default, i opened the sip port from public to the Gatway ( private ip) in both direction but i cann't connect.
Note taht i use Static NAt for Gatway here under outr configuration
static (inside,outside) 82.10.229.100 10.10.100.8 netmask 255.255.255.255
service-policy global_policy
Class-map inspection_default
inspect sip
access-list outside permit udp any 82.10.229.100 eq sip
access-list outside permit tcp any host 82.10.229.100 eq sip
access-list inside permiy host 10.10.100.8 any
kindly advise
regards
Anonymous (not verified) Wed, 08/08/2007 - 06:20
SIP is an ASCII-based, application-layer control protocol that can be used to establish, maintain, and terminate calls between two or more endpoints. Like other VoIP protocols, SIP is designed to address the functions of signaling and session management within a packet telephony network. Signaling allows call information to be carried across network boundaries. Session management provides the ability to control the attributes of an end-to-end call.
