problem connecting to access server
Aug 2nd, 2007
Remote users can not connect via analog modem or ISDN to 3620 access server.
The debug (debug ppp authentication, debug ppp negotiation, debug isd q921, debug isdn q931) output of unsuccessful connection from 4601111(starts 21:51:15,ends 21:51:39) is in the attachment, configuration of 3620 is also in the attachment.
Any ideas?
show modem version and sh ver are following>3620#sh modem version
Slot 1:MICA-6DM Firmware, Source - flash:/mica-modem-pw.2.9.4.0.bin
CP ver 2940 - 7/24/2002, CheckSum BB345F13.
SP ver 2940 - 7/24/2002.
MICA 0: HW Version 1.0, Serial Number 25568550.
MICA 1: HW Version 1.0, Serial Number 25568673.
MICA 2: HW Version 1.0, Serial Number 29370461.
MICA 3: HW Version 1.0, Serial Number 29528420.
MICA 4: HW Version 1.0, Serial Number 14812911.
c3620#sh version
IOS (tm) 3600 Software (C3620-I-M), Version 12.2(27), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Tue 02-Nov-04 21:42 by kellmill
Image text-base: 0x60008930, data-base: 0x60A3E000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
c3620 uptime is 5 days, 22 hours, 53 minutes
System returned to ROM by reload
System image file is "flash:c3620-i-mz.122-27.bin"
cisco 3620 (R4700) processor (revision 0x81) with 28672K/4096K bytes of memory.
Processor board ID 22866774
R4700 CPU at 80Mhz, Implementation 33, Rev 1.0
Channelized E1, Version 1.0.
MICA-6DM Firmware: CP ver 2940 - 7/24/2002, SP ver 2940 - 7/24/2002.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
31 Serial network interface(s)
30 terminal line(s)
1 Channelized E1/PRI port(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Overall Rating: 1 (1 ratings)
MarkDeibert1 Thu, 08/02/2007 - 13:45
ASA-AIP-CLI(config)#show running-config
ASA Version 7.2(2)
hostname ASA-AIP-CLI
domain-name corp.com
enable password xxx
names
interface Ethernet0/0
nameif Outside
security-level 0
ip address 172.22.1.163 255.255.255.0
interface Ethernet0/1
nameif inside
security-level 100
ip address 172.20.1.1 255.255.255.0
interface Ethernet0/2
nameif DMZ
security-level 50
interface Ethernet0/3
nameif DMZ-2-testing
security-level 50
ip address 192.168.10.1 255.255.255.0
interface Management0/0
shutdown
no nameif
no security-level
no ip address
passwd xxx
ftp mode passive
dns server-group DefaultDNS
pager lines 24
mtu inside 1500
mtu Outside 1500
mtu DMZ 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat-control
route Outside 0.0.0.0 0.0.0.0 172.22.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
