Cisco 837 - VPN only connects if PC is turned on on LAN
Aug 2nd, 2007
We have an Cisco 837 ADSL router that connects to our Cisco Concentrator. The only way I can get the tunnel up is if a user turns there PC on that is plugged into the ethernet port on the back of the 837. If it's off and the router is rebooted the tunnel stays down. Why does it need a PC to bring the tunnel up?
mattiaseriksson Thu, 08/02/2007 - 01:25
  • Bronze, 100 points or more
You are using the easy vpn feature?
Verify these statements in the config:
crypto ipsec client ezvpn XXX
connect auto
whiteford Thu, 08/02/2007 - 01:54
It's CLI I'm using:
I have a crypto ipsec transform-set xxx
mattiaseriksson Thu, 08/02/2007 - 02:04
Ok, so you also have a crypto map containing "set peer" and "match address" statements?
Then you use a normal IPSec tunnel that will only initiate when it sees traffic defined as interesting in the crypto ACL (match address).
Check out the EasyVPN feature if you want the router to connect automatically.
Example: http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080809222.shtml
