ISDN Outbound call issues
darkbeatzz
Hi All,
I have 2 routers which connect to each other using dialer profiles on each router. THe problem I am having is from one router I can initiate the call and pass traffic no problem. but if I kill the call and try and bring up the call from the other end it will not come up.
What sort of things should I be looking for here?
thanks a mill
mick
10 Replies 10
are_khatri
is it possible for you to post configuration for both routers.
spremkumar
Level 9
Level 9
Hi Mick
Have you configured both dial in/out profiles on both the sides ?
Also any reason behind having this kinda 2 way mode deployment ?
The best way would be having one side dialing out and the other side to accept the same.
So that you can have the control on the isdn bills getting generate every month :-).
regds
I cant post the configs at the moment I dont have access to the routers I will post them later though. Its a fairly complex network with full redundency. Primary access is using leased lines and there are many routers and companies in the mix. I could be typing all day describing the setup and I would if I had the time!!
so when I initate the call on the router that is having problems making the call I do a debug ppp auth on the router on the other side. It sees the other router dialing in but is giving an authentication fail message.
The username that each device uses to auth is the router name yeah? so on the local router there should be a username setup with the remote routers name?
thanks for the replies
On the local router you should be having the remote router's username & password credentials...
regds
thanks.
does the remote users name have to match the remote router name?
sorry that should read does the local username for the remote router have to match the hostname of the remote router
yes it should match the hostname of the remote thats the general practise being followed up..
regds
OK so the problem is not auth.
the far end accepts the call and hangs up after 20 second but no traffic goes to it..... Im a bit stumped here....
Once you are connected did you check whether you are able to ping the remote end dialer interface ip ?
How did you check about traffic passage over that link ?
is your primary link up when you are trying with this option ?
regds
Config from router(hutch) that cannot pass traffic to other router(lisa) - this router has a pri configured to numerous other different sites and works no problem
interface Dialer32
description ##xxxxxxx##
ip address 172.16.9.18 255.255.255.252
encapsulation ppp
dialer pool 1
dialer remote-name met-test
dialer string 1234567
dialer hold-queue 50
dialer max-call 2
dialer-group 107
no cdp enable
ppp authentication chap
ppp chap hostname hutch
ppp multilink
access-list 107 deny icmp any any
access-list 107 deny udp any any eq syslog
access-list 107 deny udp any any eq ntp
access-list 107 deny udp any any eq snmp
access-list 107 deny udp any any eq snmptrap
access-list 107 permit ip any any
dialer-list 107 protocol ip permit
Config from lisa which can dial out no problem
interface BRI0/0
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
isdn caller 78912345
no cdp enable
ppp multilink
interface Dialer10
ip address 172.16.9.17 255.255.255.252
encapsulation ppp
dialer pool 1
dialer remote-name hutch
dialer string 8701100
dialer-group 107
no cdp enable
ppp chap hostname met-test
ppp multilink
access-list 107 permit icmp 0.0.0.112 255.255.255.0 0.0.0.112 255.255.255.0
If there are any debugs that may be useful here let me know and Ill post them. thanks a mill
The only deviation i am seeing here is the ACL 107 in the routers.
In Lisa router i couldnt understand the concept behind having the first line of ACL 107.
If it doesnt hold any value can you modify the same by removing the first line and check ..
regds
