VTP domain mis-match
Answered Question
Aug 2nd, 2007
Can anubody help to troubleshoot VTP domain Mis-match. I am getting the follwoing message in my switch.
switch(enable) sh trunk 2/2
* - indicates vtp domain mismatch
Port Mode Encapsulation Status Native vlan
2/2 on dot1q trunking* 1
Yagnesh Dave
Correct Answer by Jon Marshall about 9 years 11 months ago
As you can see from your second switch there is no domain name set.
But your first switch has a domain name of mpls. If you want these two switches to exchaneg VTP information you will need to make the domain name match.
But it's not as simple as that. Both your switches are in VTP transparent mode so i'm guessing you don't want a VTP server/cleint setup in your network ?
Jon
Overall Rating: 4 (1 ratings)
Jon Marshall Thu, 08/02/2007 - 01:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Can you post output of "sh vtp status"/ "sh vtp domain" from both switches.
Jon
yagnesh.dave Thu, 08/02/2007 - 01:54
Hi Jhon,
Here is the output of sh vtp domain:
switch(enable) sh vtp domain
Domain Name Domain Index VTP Version Local Mode Password
mpls 1 2 Transparent -
Vlan-count Max-vlan-storage Config Revision Notifications
725 1023 0 disabled
Last Updater V2 Mode Pruning PruneEligible on Vlans
192.168.1.252 disabled disabled 2-71,73-98,100-105,107-129,131-140,142-151,153-1000
yagnesh.dave Thu, 08/02/2007 - 01:57
Hi Jon,
Forgot to past the output from the other switch
Switch2#sh vtp status
VTP Version : 2
Configuration Revision : 0
Maximum VLANs supported locally : 1005
Number of existing VLANs : 122
VTP Operating Mode : Transparent
VTP Domain Name : ''
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x66 0x51 0x7A 0x50 0x24 0x25 0xDF 0x33
Configuration last modified by 172.16.69.2 at 0-0-00 00:00:00
Correct Answer
Jon Marshall Thu, 08/02/2007 - 02:57
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
mohammedmahmoud Thu, 08/02/2007 - 03:20
  • Green, 3000 points or more
hi,
Just a small addition to Jon's post, if the switches are server/client, then the switch having null domain name will learn the VTP domain name from the other switch.
HTH,
Mohammed Mahmoud.
